Author Topic: Some Albums Not Being Identified In MusicBee  (Read 988 times)
mm
New user. I have created a new test library to learn more about Musicbee workings before diving in.
https://imgur.com/a/SnifQoU
The 3 albums are all in the same folder.
Only 2 of the 3 albums have been identified by Musicbee, presumably due to the info included in the tags.
https://imgur.com/a/hSkQaj5
What is the best/easiest way to correct this (as I am sure I will encounter this a lot).
Last Edit: July 30, 2019, 02:18:08 AM by mm
Well, it looks like you have the album and album artist. I bet if you add those manually (you can do all tracks at once) and then try auto-tag by album, you'll probably find it then. Assuming it's in one of the databases MusicBee uses.
mm
When you say add the album manually, do I need to manually remove the one album that was not recognised first?
Can I ask what the manual adding procedure is please?
You don't need to remove anything. Select the files for ABC - Traffic and open the tag editor (right click, Edit or press Shift + Enter). Then you can type them in.
captain_paranoia
Your files are missing metadata tags.
Since you seem to have well-formed filenames, you could also get MB to infer metadata from the filenames.
Select album.
Tools/Tagging Tools/Auto-Tag by Track/Infer and Update Tags from Filename
Use the template:
<Album Artist>-<Album>-<Track#>-<Title>
Last Edit: July 30, 2019, 09:23:57 AM by captain_paranoia
Not the answer you're looking for, but it might also be a good time to start a new project converting your .wav files to .flac.
Tag support for .wav files is a lot better than it used to be, but still nowhere near as robust as for .flac.
And you'll save a lot of disk space too!
