My music files are in order. I have a master folder called "Music" with 42 sub-folders, each for a different complete album. I've looked at preferences > library > monitor folders and it is pointing to "Music." If I select Choose Folders in library preferences, then all of my folders are under Music and they are all checked. If I examine the actual folder of the one I used as an example before, it has 11 tracks. Yet Musicbee only shows 2 tracks of the 11. (I haven't gone through all 42 sub-folders to see if the rest are complete, or if some of the "missing" tracks are in the wrong folder in Musicbee.)
Musicbee appears to "forget" several things. I can drag files from the actual folder into the album on Musicbee, and all the tracks are there. But after some time (1, 2 or more restarts of Musicbee?), the album reverts back and many of the tracks disappear from Musicbee.
The other "forget" is if I click and drag to re-order tracks in an album, that sticks for a while. And then on another restart of Musicbee, the tracks change to a different order.
I suspect my physical storage is just as likely to cause this problem as it is to display the post which I assume you really sent.
Thanks for your time and consideration.
Dave
Ooops. New reply by psychoadept.
I don't know how Musicbee orders music. In my folder, it's alphabetic. In Musicbee, it is not. As I said above, I can click and drag a track in the "Playing Tracks" window and change the order. I mostly want to do this with individual tracks I've purchased and put into one folder..
I don't know how to show you that Musicbee has 2 tracks and my folder has 11 tracks without creating a url. Too much trouble.
BTW, I did install v3.3.
