MB 3.3.7143 P
Using Auto library report to create virtual tag
Album Max. (Play Count) = $ALR(<URL>,Max:PlayCount)
works the most of the time, but have about 20 albums (with nothing similar about them that I can tell) that aren't correctly transfered.
From the image, you can see that the report correctly identifies the highest play count among the album tracks, but when it comes into MB it becomes 47.
I'm only assuming that this is a bug in MB, as the count is correct for the ALR and it's not occuring for all tracks.
