MB: 3.3.7145 P
FiiO M11, Android 7.0
MTP only, no mass storage support.
I've recently moved a micro SD card from my FiiO X5 Gen 3 to my new M11. Syncing over MTP using the same settings as previously used for mass storage sync on the X5. The only issue I've encountered with syncing is the playlists.
Formats tested (and supported by the device manufacturer):
M3U
M3U8
Issue:
When viewed with Notepad, tracks in the playlist are not listed on new lines.
..\Track1..\Track2..\Track3..\Track4..\Track5 etc.
I cannot reproduce the issue with a virtual device and it did not occur on my X5. Editing the tracks of an affected playlist in Notepad thusly:
..\Track1
..\Track2
..\Track3
..\Track4
..\Track5
and then copying to the device via File Explorer results in a readable playlist. It also works normally if I copy the synced playlist from the virtual device to the M11.
Has anyone else come across this or can anyone reproduce it? I'm hoping I'm just missing a setting somewhere.
Edit: I should probably add, the tracks in the playlist can't be read by the device if they aren't on separate lines.
Last Edit: July 27, 2019, 01:10:44 AM by CritterMan
