Author Topic: New version naming convention adopted(?)  (Read 1154 times)
Just updated to the latest patch and noticed there was a slight delay at startup(only once), and the version number shows as "3.3.7134P".  I have the Portable version;  is the added "P" to the version number part of the MB-type ID that was discussed on the forum?  I assume then that the initial delay was due to the patch "scoping out" the MB version it was being applied to.  Hey, good idea and glad to see it implemented so quickly!
Sure looks like it.
And thanks. But my idea was based on your idea.
https://getmusicbee.com/forum/index.php?topic=29094.msg162048#msg162048
Yes i tweaked the version label as suggested. There is no reason for the startup to take longer
I saw no delay in startup.
Are the other letters 'S' for Windows Store and 'I' for Installer?
Thank you!  Only the very first startup was slightly longer than I expected and was not repeated;  probably just chance from the combo of other stuff I had running.
Will the letter show up in the error log when a user is pasting to the forum?
