Author Topic: Syncing to the device failed  (Read 2215 times)
ucynml
Hello.
Syncing playlists doesn't finish in version 3.3.7115.
Synchronization always fails on the way, but I can't reproduce where it stops.
Copy Failed - Library, drive or media pool is empty. (Exception from HRESULT 0x800710D2)
MusicBee 3.3.7115
Deivice: SOV36 (Xperia XZ1)
ucynml
Thank you for your reply.
I tried the patch, but the issue was not solved.
Synchronization stops after all.
I dont think i can help further.
This is what the error code means:
"May be used to indicate that the device failed to send any resource data when resource data was expected (e.g. a thumbnail or device icon). This usually indicates an error on the device."
