Author Topic: Can we sync playlists and library with windows media player?  (Read 2821 times)
Joeggernaut
I want to sync musicbee library with windows media player given that upnp plugin doesn't work (100% cpu usage) and I am able to stream music using windows media player but I prefer musicbee to manage everything.
I'm not sure if you can, but if you do, be aware that WMP has a tendency to really mess up your tags.
It could be done but someone would need to write a plugin.
This is actually a good time for me to spend some time on the Upnp plugin, so if you are willing to run a debug version let me know
edit:
try this version of the upnp plugin which might solve the 100% cpu issue:
https://www.mediafire.com/file/4vvpxv0m4fs0vb6/mb_Upnp.zip/file
unzip and copy into the Plugins folder
Last Edit: June 24, 2019, 09:22:55 PM by Steven
jasongnome
Quite, that's why I dumped WMP all those years ago.
More info on that here: https://getmusicbee.com/forum/index.php?topic=20204.0
jasongnome
That's not it's only problem. It is, by default, set to "correct" tags from the Internet, and turning it off doesn't work. Many of these "corrections" are actually wrong. While I was still using it, I went to Miscrosoft's own help site and loads of people were reporting the same problem and none of the solutions put forward my Microsoft staff worked.
It also routinely messes up capitalisation, and changes it back to what it wants if you try to change it manually. Useless piece of software.
It's not only tags it has problems with. My old laptop suddenly stopped working unless in safe mode. Basically on startup it froze after being on for about 5 minutes. I decided to to a full reinstall of windows so started manually backing up files so I could. Two of my music files were corrupted. When I researched the issue, WMP re-indexes music files on startup (whether you want it to or not) and it was hanging on the corrupted files. Once I'd deleted those two files the laptop worked fine again.
