Author Topic: Now playing bar over column browser  (Read 4269 times)
drag the cursor above the top of the application window or down below the bottom of the now playing bar?
Do you mean dragging the top border of the now playing bar, or just moving the cursor? Cursor moves fine to any place.
that - are there any y-axis barriers to where the top border can be dragged to other than the screen barrier
Freddy Barker
  • 🎧 MB 3.4.7628P
...My screen resolution is 1600x900...
On 1600x900 - the only thing I have noticed that looks a little off is the top of the text "Processing....15 of 199 files" as in screenshot:-
Last Edit: June 15, 2019, 04:56:34 PM by Freddy Barker
No barriers. If I drag it down out of the application window, it gets a negative number as height value in the settings file.
in that case i feel confident in saying its the windows ClipCursor function that is not working for you. I have no idea why that would be.
I can look to make an enhancement in v3.4 to work around the issue
Last Edit: June 15, 2019, 04:46:38 PM by Steven
