Author Topic: Remove the left panel only on ONE tab  (Read 1362 times)
coco1602
Hi ! I'm looking for a way to remove the left panel only on one tab : the album tab (https://i.imgur.com/xDDesa6.jpg) and keep it on all the others (https://i.imgur.com/uGlgpZ7.png)
I tried View - Arrange panels - Remove left main panel but by doing that, it removes it from all the tabs...
Hi, welcome to the forum!
You were in the right place. If you look at the bottom right of the Arrange Panels window, you'll see a section that says "overrides for the current musicbee tab". That's where you can hide the sidebars for individual tabs.
coco1602
Thank you for your kind and quick answer ! It's perfect !
This software never ceases to impress me  ::)
