Author Topic: Editing the Mood Tag  (Read 2216 times)
erlian
Is there a way to configure the mood tags? Add/remove moods, rename moods, group moods?
Trying to experiment with new ways of organizing! If all else fails I know I could make custom tags.
jippijip
The list of available moods can be edited in configuration.ini file, though it gets overwritten during updates. As for grouping them, I think you're out of luck, though it would be a cool feature to have!
It's configuration.xml and it's in the same folder as MusicBee.exe
