Currently, when MB is opened you need to click the searchbar then type what you search.
It would be great if you could remove the " click the searchbar " step, this way when the MusicBee windows is opened if you type something it will automatically search what you are typing, it may sounds stupid but this little improvement is very useful and save time.
I know such a feature exists for Windows Media Player (and probably a lot of others) so this is definitely something doable.
Thanks.
