Author Topic: Switching from iTunes to MusicBee  (Read 1109 times)
kittent
A) I installed MusicBee and it work for a short while. I closed it and it won’t reopen. 😿
B) I want to use MusicBee to hold my library so I can create playlists
C) I need an Idiots Guide because my home IT guy doesn’t do iTunes or Amazon Music and he can’t help me.
Help, please!
kittent (aka Barbara Trumpinski-Roberts
Probably it's something your security software is doing. Try whitelist MusicBee with the program:
https://getmusicbee.com/forum/index.php?topic=23939.0
Once it gets cleared, you can import your iTunes library using File> Library> Import> Import from iTunes menu.
