Author Topic: wrong info -artist bio, lyrics  (Read 1306 times)
maricusa
I find several errors in lyrics and/or artist bio-- how do i "insert" correct  info.  -- copy /paste does not work
Bizy
Hé Maricusa,
Regarding lyrics:
There's many ways to adjust lyrics.  For instance:  in Main Player, right click in the Lyrics panel (if not visible, make it visible via 'Arrange Panels'.)
If you have lyrics in your clipboard:  that should work ('Paste Clipboard Lyrics into Music File').
You can search for other lyrics.  And you can tell MB where to look:  in Edit/Edit Preferences/Tags (2) - Auto-tagging - Lyrics.  (And you can install the 'Lyrics Reloaded' plugin to install more lyrics providers. And/or other plugins.)
Does that help?
b.
Last Edit: May 30, 2019, 01:11:50 AM by Bizy
Full installer Version 3_4_7805
Portable Editon 3_4_7805 P
OS: Windows 10 Home Edition
