Author Topic: Some advice on using the computer node  (Read 2418 times)
StardustNightwind
Hi everyone. Is there a way to make the computer node load album art for albums that are not yet in the library? Since I'm still discovering the anatomy of MusicBee, I only loaded a part of my music into the library; and I'm using the computer node for the rest. I already have .jpg album arts in the album folders but computer node doesn't load them unless I use "File Rescan" option.
Here's a snap of what I mean.
https://i.ibb.co/5LpbS2v/ice-screenshot-20190520-222151.png
Last Edit: May 20, 2019, 09:27:55 PM by StardustNightwind
That's expected. It only shows embedded covers and won't show other types of artwork even if you reopen the folder multiple times since they are not imported to your library.
If you select those files in the main panel and run file rescan, then it searches and displays artwork as set in Preferences> Tags (1)> Edit List.
StardustNightwind
I see. Then, if it's expected, I'm fine with it. Thanks for your reply.  :)
