Author Topic: [Beta] [1.2.1] LuaBee - Lua scripting engine for MusicBee  (Read 9124 times)
DJ MADEST
Hello! I am developing a plugin that allows you to load Lua scripts, thereby expanding the functionality of the player. The advantages of this approach are obvious - the simplicity and speed of development. Of course, at the current stage of development, scripts cannot replace plugins, but writing simple automation algorithms is much simpler on scripts than on plug-ins.
Warning: This plugin is under development, global API changes and random crashes are inevitable.
Documentation is under construction at: https://lainez.gitbook.io/luabee/
Download (v 1.2.1): Download
Simple script example
-- Very simple example: Pauses the track if volume level in player is 0
-- Some variables
-- in Lua it is common to use local variables
local EVENT_VOLUMECHANGE = 6 -- Volume change event ID
local volLoop = false -- prevent looping =)
-- Callbacks
function ReceiveNotification(source, event)
    if event == EVENT_VOLUMECHANGE then
        local volume = GetVolume() -- gets volume level
        if volume == 0 then
            SetPlayState("playpause") -- set playing state
            volLoop = true -- prevent looping
        end
        if volume > 0 and volLoop then
            volLoop = false
        end
    end
end
Last Edit: May 22, 2019, 06:20:20 PM by DJ MADEST
DJ MADEST
Version 1.1.1
Scripts manager:
+ 2 new buttons - "Lookup new scripts" and "Open scripts folder"
API Changes:
+ SetAutoDJ()
+ MbUI:AllocalateConsole()
+ MbUI:PrintConsole()
Description for new functions you can find on docs
Last Edit: May 22, 2019, 06:21:26 PM by DJ MADEST
DJ MADEST
Version 1.2.1
API Changes:
+ CreatePlaylist
+ PlaylistSetFiles
+ RemoveFileFromPlaylist
+ RemovePlaylist
Fixed bug with ReceiveNotification when the event argument were not valid for Lua datatype
zkhcohen
Hey! This seems like a really cool project.
I'm used to creating add-ins in C# - could you provide some sample projects in lua?
DJ MADEST
Yes, i'm working on it...
imax
Can you post a link to your github repo, so we can read the source code and maybe send you some pull requests?
