Author Topic: A quick Question regarding FLAC  (Read 4235 times)
Mobbsypom
Sorry to trouble the team,
I have recently upgraded to the new version of Musicbee,and at the same time moved my small library of music (around 1Tb of MP3s at 320)..
in doing so I found an album of Flac files..so wanted to convert them to MP3 for consistency across the library;all the codecs are in place,I have configured the File Converter preferences to Maximum quality,and yet the files get converted to 160Kb..is there something in the source file I need to check?
Thanks in advance
If you look at your File Converter preferences, is this what it shows for maximum quality under MP3/Lame:
--cbr -b 320 --noreplaygain - [outputfile]
Mobbsypom
psychoadept,
yes exactly that
I will try on another bunch of flac files to see if it is on the flac side
Cheers and thanks
Mobbsypom
OK...so tried on another flac file...not a problem..straight to 320...must be the original files I found...looking at them..they do seem a tad smaller than most flacs..(on a non scientific comparison to other files!)
thanks anyway..
Cheers
