Author Topic: MB stops working  (Read 967 times)
jokkebal
I use MB via Parallels on a Mac. When I add an album graphic to a series of songs and when I delete one song while MB is saving the songs, MB stops responding and needs to be restarted. I have the impression that the slightest effort is too much.
How can I see if this is a memory problem ?
Thanks.
I would suggest taking your issue to a Mac or Parallels forum since MB is made for Windows. Yes, some people are running it on Linux and there may be some running on Macs, but we can't troubleshoot issues you're having on a non-Windows machine.
I would also suggest searching the forum here just in case someone else is using MB on a Mac, but I don't recall ever seeing a Mac question before.
Why are you deleting a song that hasn't been saved yet?
jokkebal
No, MB is saving graphics in a series of songs and meanwhile, I do something else within MB, e.g. deleting a(nother) song.
jokkebal
reply to phred : parallels is a tool which enables to run windows on a mac. It's a virtual environment. Just added that info to be complete but it definitely is a windows environment in which I run MB.
I think I saw something similar before, but I don't remember the detail. If you can reproduce the issue step by step, file a bug report.
