Author Topic: Update Splash  (Read 1442 times)
Chaython
Still says 3.0
Build 3.3.7052
I assume the splash is just an image; and it's redundant work to update it... But it may confuse some people.
The latest MusicBee patches.
Chaython
On another note, the newest build seems more resource heavy <1.3% CPU 71.5mb; previous builds were ~0% 40mb
Also the newest build requested firewall access, previous builds did not; I assume this is related to the new wifi syncing feature, though it is disabled.
Speaking of confusing, your sig is referencing MB versions that are almost two years old and no longer supported. That's not helpful to users. Please keep it current or don't use it at all.
Still says 3.0
Build 3.3.7052
Splash image is skin dependent. I guess you're using a skin that hasn't been updated for a while. You might want to notify the skinner to update it.
