Author Topic: System.NullReferenceException  (Read 2526 times)
Navigator Black
Long time Musicbee user, first time poster.
I can't seem to figure my way around this error:
MusicBee v3.3.7050.29117 (Win10.0), 21 Apr 2019 12:56:
   at CubeIsland.LyricsReloaded.LyricsReloaded.shutdown()
   at CubeIsland.LyricsReloaded.LyricsReloaded.Finalize()
When starting up MB I get this Windows dialogue box error:
An error occurred during plugin startup:The process cannot access the file.
'C:\Users\myaccount\AppData\Roaming\MusicBee\mb_lyricsReloaded\mb_LyricsReloaded.log' because it is being used by another process.
I removed the mb_LyricsReloaded items from my installation but it still gives me this error. And MB doesn't stay open after saying OK to the error message so I can't make any changes to MB itself.
MB was playing fine then after a few songs this error appeared and crashed the app.
Help?
When this error occurs it usually means that you've got two copies of the plugin, likely one in your plugin folder wherever MB is installed and one in %AppData%\Musicbee\Plugins.  Make sure only one instance of mb_LyricsReloaded.dll is active.
I've also seen it happen when you have a hidden instance of MB running from a previous crash that is hiding in the task manager, but it's usually the first thing.
Last Edit: April 21, 2019, 10:44:30 PM by frankz
Navigator Black
Hi Frankz,
That worked, thank you! There was a copy of the .dll in the Plugins folder which I hadn't noticed.
