Author Topic: Adding Folders to Musicbee  (Read 8573 times)
bobgunson
Hi
In the musicbee dropdown tab there is the option to add file how can I add a single folder for example add folder from usb memory stick
when i select a folder it opens up and displays individual tracks
Thanks Bobgunson
You would use the option to scan new files from the File menu, and choose just that folder to scan.
bobgunson
