Thanks for your reply. Let me comment on it.
If, for example, I had removed a number of junk tracks from my main MB library because I never really liked them, and then later during a "sync" the junk had been reintroduced back into my library....Well!
This is different situation, I think: I did not remove any tracks from MB (the tracks are still listed in MB and part of playlists to be synced). But the underlying files were deleted for any reason, by accident mostly (MB bug or awkward usage like a portable install on a SD card, or an unvoluntary deletion by the user), and without me being aware of it, that's the whole point.
I can see what you're saying here, but if any of my tracks had been accidentally or otherwise deleted, then assuming I eventually noticed, I would go to my other PC, USB HDD, BT Cloud or Google Music and grab them back!
The problem is that I wouldn't have even noticed that the underlying files had disappeared in MB if I hadn't scrutinized the sync previow log, wondering why this file would be deleted from the device, or even worse, why that file that I just had added to the playlist would not appear in the preview at all... because their underlying files were missing. Having a message in the log saying "missing file on PC" for both cases would have helped me a lot. Then I could have stopped the sync and solved the issue.
So, actually, if really the sync behaviour itself cannot be changed, it would already help a lot if in these 2 cases (a new track to be synced or an already synced track, both without any file on the PC), the sync log could display an entry with an explicit warning message.
I hope this clarifies
And by the way, an option to activate the "Sync" button only when the "Preview" is done first, would help a lot as well, but that is more a wish I have to file in the right section of the forum
[EDIT: done]
Thank you
