Author Topic: Wifi android device synching  (Read 431581 times)
kimt1688
I'm not sure if I should start a new thread for this but I'm unable to sync playlists to my Fiio M11S.
Its reporting the following in the WiFi sync app:
2025-04-03: FiO M11S; 10; 2.1 09:17:32: createFile: Music/Playlists/
100 Been A While.m3u8: android.data base.sqlite.SQLiteException: no such table: audio_playlists_map (code 1
SQLITE_ERROR):, while compiling:
DELETE FROM audio_playlists_map
WHERE ((playlist_id='34047)), folder= content://com.android.externalstorage
.documents/tree/external_sd%3A /document/external_sd%3AMusic
%2FPlaylists
09:17:32: receiveFile: android.datab ase.sqlite.SQLiteException: no such table: audio_playlists_map (code 1
WHERE ((playlist_id='34047)): file=Music/Playlists/100 Been A
While.m3u8
100 Least Played Favourites.m3u8: andr oid.database.sqlite.SQLiteException: no such table: audio_playlists_map (code
1 SQLITE_ERROR):, while compiling:
WHERE ((playlist_id='34048)), folder= content://com.android.externalstorage
.documents/tree/external_sd%3А /document/external_sd%3AMusic
%2FPlaylists
SQLITE_
WHERE ((playlist_id='34048')):
file=Music/Playlists/100 Least Played
Favourites.m3u8
Any idea what might be wrong?
TIA
What versions are you using for MusicBee and MusicBee Wifi Sync app?
Also, please send me a screenshot of the device settings for MusicBee.
KenDavies
Musicbee is version 3.6.9202 P but I can't find a way of seeing the version of WIFI sync on the M11S. Edit: my mistake, it's version 2.1, I've been unable to get later versions to work at all as the M11S uses Android 10.
I'm afraid I can't post a screenshot as Imgur says it's "over capacity". Second edit: Imgur's back up and running:
Last Edit: April 04, 2025, 01:53:53 PM by KenDavies
kimt1688
Version 2.7.19 is now available in β release.
The changes are the replacement of ProgressDialog, which was used in two places: the registration process of all files to the MediaStore and the deletion of all playlists.
With this substitution, both processes can now be canceled, but there is no guarantee of operation by quitting in the middle of registration or deletion.
Cancellation does not destroy the file.
The ProgressDialog is deprecated and the reason for this is that it is a modal dialog.
This update brings the App closer to Google's regulation.
Last Edit: April 07, 2025, 01:07:07 PM by kimt1688
Just grabbed the latest beta and want to report it's working quite nicely. I synced to three devices, each with its own profile (set in MB) and it all went well. Files that needed to be deleted were deleted, new playlists added, old playlists update. All without issue.
Thanks for keeping this plugin alive and well.
kimt1688
I have finally upgraded my device to Android 15.
I'm thinking of releasing the next beta version with only changes to the screen, rather than adding or improving functions.
The initial settings screen and error log screen can be done without connecting to MusicBee, so I've already finished improving them using an emulator.
I'm thinking of applying the same improvements to the remaining screens, and then releasing the beta version after checking it on Android 12, 14, and 15 devices.
kimt1688
Version 2.8.0, which supports the screen layout of Android 15, has been officially released.
This is the official version, not the beta version. I made this decision because there are more Android 15 users than I expected.
I have tested the display on Android 12, 14 and 15.
I think this will clear up the error log problem and the Sync button problem for Android 15 users.
I have confirmed this on both the 3-button navigation and gesture navigation.
shinjibi
Is it possible for Android to "clean up" the MusicBee sync settings if I do not use it in a long time? I did not use it for a few months and it is no longer working. I updated both MusicBee and the sync app to the most recent version.
BoringName
Check the app permissions, Android will disable permissions on apps if they have not been used in a while unless you tell it not to for the specific app.
shinjibi
Ok, all the settings are the same. I am still getting a notification that Sync and MB are not connecting and that it might be behind a firewall. I've disabled Windows Defender for now. Is there a way to check if the MB server is running?
The "MB server" is MB. If MB is running/launched/open, then the server is running.
As far as cleaning up the WiFi sync settings, you could try uninstalling and reinstalling the app.
What version of MB are you using?
What version of the app are you using?
shinjibi
Ok, it's definitely running. Could be a router issue. What ports does MusicBee use?
I'm on Musicbee Portable 3.6.9202 P and the most recent beta of the Wifi Sync app.
MB doesn't use any ports for the WiFi Sync app. As long as MB and the device are on the same WiFi network, they (should) connect.
ACardAttack
Im on 2.8.0 and every time I want to wifi sync, it wants to delete every track on my phone first.
I used to have this issue on the official version once in awhile.  I did delete my device and resync and it fixed it for a little bit.  I've cleared the data.
I suspect if I move all my music from /music, to music/music on my device it will work, that is what I used to have to do to get around this, but its annoying to keep doing.
I checked my device preferences and nothing has changed
I have nothing further to offer. You'll have to wait for the plugin developer to comment.
kimt1688
The only thing that is deleted independently by the Wifi Sync App is the entire playlist.
Everything else is deleted according to the deletion instructions from MusicBee.
Does the same thing happen with wired sync?
Is this a problem specific to the Wifi Sync App?
