Author Topic: Wifi android device synching  (Read 428079 times)
Haljeff
Anybody able to get Poweramp playcounts to sync in android 13+
BoringName
You need the paid version of Poweramp for it to work.
If you have the paid version and it's still not working, the only thing I can suggest is changing to GoneMad as I know that works. You need the paid version for that too.
sjc91
There is no sign of the musicbee wifi sync app on the playstore.
Is it safe to just download the apk from here or something similar?
https://musicbee-wifi-sync.en.uptodown.com/android
also is the MB wifisync app the only way to allow 2-way sync?
BoringName
Considering it has Steve's name on it and it's dated October 2023, which is years after he stopped releasing updates, it's either a dodgy file or they have scraped it from somewhere else to generate traffic to their site. Either way it's probably not going to work if you are on Android 13 or later.
If you go back a few pages in this thread, some people have provided links to updated versions that should work. One of them is mine but I compiled that a year and half ago, there might be better options.
Just regarding the google play store, the app I uploaded has been delisted by Google as it is missing a data safety form and requires resubmission but I dont think MB is compliant any more and wont pass the submission test. I dont want anything more to do with maintaining the app or the google process so wont take any action.
kimt1688
I continue to maintain it for my own use and also publish a degud build version.
↓ Here
https://tkland.kim/?page_id=3239
If there is no problem, I will use MusicBee Wify Sync
Is it okay for me to take over the future development of the game and go through the process of publishing it on the store?
Sorry, I am Japanese. English is translated by Google
Yes its fine with me. The original version of the app I created has been de-listed from the Store in any case
Just a thought: perhaps publish it on a site such as F.Droid instead of on 'The Store' to avoid any hurdles and problems with Microsoft?
maybe with Google?
arcendus
↓ Here
Thank you so much for this! I used your apk just now, after the hacked apk I had been using up until now stopped working, and it works great. This is a lifesaver, and I am tremendously grateful.
sjc91
↓ Here
Thanks for this :)
jmn
↓ Here
Can anybody tell me how to use this? Thanks for sharing!
kimt1688
↓ Here
This is a tool for cable-free synchronization between MusicBee on a PC and an Android device.
You must first connect and sync with a cable once.
You do not need to enter the IP address of the server, but please make sure that the PC on which MusicBee is running can communicate beyond the firewall.
Next, choose whether you want to save the music files to internal storage or an SD card.
Finally, Sync and they should be synchronized. That's all there is to the tool.
Translated with DeepL.com (free version)
Last Edit: May 19, 2024, 10:25:14 PM by kimt1688
jmn
↓ Here
My bad, it does work. Not sure why when I was downloading from my phone, it was considering the file as a zip. I downloaded from my PC and now it's fine. I get errors about the artworks, but that's not a big deal.
Thanks again for your update!
trtlcake
Thank you for doing this, it seems to work for me. However, the ratings do not synchronise from Gonemad to Musicbee. Can you advise whether this should be working? Perhaps it is just an issue on my end.
