Author Topic: Wifi android device synching  (Read 444533 times)
ome-reily
Shougun, have you tested if you can sync playlists with this setup? Also how long does the sync with syncthing take you? Thinking about using this since the wifi sync app is no longer working.
Shougun
Sorry for late reply, seems to work rather quickly. Turn my computer on, syncthing (GUI) is autostart, phone has it running in the background, basically when I get to musicbee it's all been done.
Two way sync of files, things that are stored in the file that convince the program that something has changed. I don't think GMMP writes everything to file, so like playcount I'm fairly certain is stored just in GMMP's database, probably tag changes too, so.. do that stuff on your PC lol. Avoid conflicts by ensuring you don't change a file prior to the phone and PC match.
Have not tried playlists, but honestly I don't see why not so long as both GMMP and MusicBee agree on file type. If MusicBee stores a file then syncthing could pick it up, and if GMMP writes changes to the playlist then you'd get those back the other way. Now I've never used GMMP playlists, but a quick google makes me think it's worth a shot: https://www.reddit.com/r/gonemadmusicplayer/comments/btr3b4/playlist_options/
Only hurdle you might have is if your phone has goofy file setting permissions, may need to slap the phone a few times and tell it you're the captain. For reference my phone is not rooted, but I did have to tell it "no, I want it to access my stuff- shut up" lol.
dalenyd
I only compiled this last night, so I've only tested this on my Android 13 Pixel 4a.  It worked perfectly.
Here is my compiled APK VirusTotal Scan
Instructions (on a Pixel 4a, Android 13 anyway):
  • Uninstall existing version of the app if installed
  • Download APK on the device
  • Open the APK, usually from the notification that the file is downloaded (might also need to give Install unknown apps permissions for your browser)
  • Select to Install from the Package Installer window
  • If you get "Unsafe app blocked" from Google Play Protect, choose More details, then choose Install Anyway
  • Once installed, choose Open
  • The "All files access permission" window should open, choose MusicBee Wifi Sync
  • Select the Allow access to manage all files toggle
  • Press the back button at the top corner
  • Press the back button at the corner again
  • You should now be in the app and can choose your server/PC
Thank you for compiling and posting the APK! I tried it, and it did work (it was syncing), but I've noticed that the playcounts were not changing. Am I doing something wrong?
@dalenyd, which android music player are you using?
dalenyd
Hi Boroda, I am using poweramp.
dalenyd
Update: I think I might have a solution to Andriod 13 not letting Musicbee Wifi Sync access the root folder.  And it’s still the old mixplorer solution (which you need to purchase for USD 5).  I reached out to mixplorer with my problem of not seeing the mixplorer panel giving me access when I launch Musicbee Wifi sync and Andriod telling me that “to protect your privacy, choose another folder.”  Here are the steps:
1.   Open Mixplorer
2.   Go to Settings > Components
3.   Enable Document Provider (all are enabled by default except this one)
4.   Restart phone (I don’t know if this is necessary, but the first time I did it, it was not working so I just restarted my phone).
The system file picker panel should be in Musicbee Wifi Sync (or any other app)
I was going crazy trying to figure this out because Musicbee has been my go to music library since my Ipod Classic died and I had to find an Andriod solution to sync my 80 GB music collection (with carefully crafted playlists over the years).
Kartoffelbrei
Out of principle: always and most definitely. ;D In case the files get deleted during the process you could make a backup of the transcoded files so you dont have to sync again in case you already did a run. There is always room for fuckups.
Just fyi. in the end i ran into too many problems with the app and now i am using the alternative "indirect method" with a secondary transcoded library and resilio. So far im quite happy with this solution. https://musicbee.fandom.com/wiki/Synchronize_Android_by_Wifi
Setup was easy. Except the fact that i didnt know i had to deselct "selective sync" for resilio to do something.
I realized that this will not work. I don't just sync my entire library, I just sync playlists. If a song is added to a playlist or I add a new playlist then the wifi sync usually adds the missing songs onto my phone, unfortunately resilio doesn't seem to be able to sync playlists.
this plugin is able to. it uses resilio as for real syncing, but also generates proper playlists for mobile devices.
Hello,
I downloaded the MusicBee Plugin. When i sync to the sync links device it just copies the files. Not with links. I didnt change anything about the settings. How come?
not sure what you mean by "links". playlists? have you set up syncing of playlists?
settings in red boxes are required, in blue box are optional:
Joemd
Is there an idiots guide to the wifi sync or something as I don't really understand what it's doing/ how it works. When I try to sync none of my playlists on my phone (using GoneMad) copy over (I receive quite a lot of "playlit files not matched in MusicBee error messages) and playlists from my computer don't seem to copy to my phone. I'm at a loss as how to have it all work.
MrVain712
Hello @all,
i have the problem again that i can sync between Android 13 and my Computer since i use a new Router.
I dont change settings in Musicbee but every Time i get now the message: "Server not found. Ensure MusicBee is running and Windows Firewall is not blocking MusicBee."
MusicBee IS running an Windows Firewall i OFF.
I restart my computer several times and my Smartphone (Samsung Galaxy S23+) too... What can i do? :(
What i dont understand in the MusicBee Wifi Sync App Error log is the message:
"failed to connect to 192.168.178.77 from 192.168.178.45...
But the IPs of my Computer is... 192.168.178.52 and not 192.168.178.77... Maybe i can change this?
i vaguely recall that IP of the phone and PC must be 192.168.0.* or 192.168.1.*
try to change the IP address range on your router.
glimpsefamerule
Just wanted to check in and mention that the Wifi Sync appears to fail if a filename contains an emoji. I was trying to sync a playlist that contained the track below, but the sync would keep failing before the filename could appear in the progress updated during the sync mode on the Wifi Sync app.
https://nmesh.bandcamp.com/album/--3
It's strange because I have a few other songs that contain emoji that seem to sync fine. Not sure if there's something in particular about this one.
ome-reily
So has anyone compiled, or can anyone compile a set of instructions for how to get syncthing working with Android and musicbee? Since the apk for the wifi sync above no long works (as I have posted about in other threads).
I'm reading through the forum and some people seem to have this figured out but it's confusing.
this (modified, not by me) apk version is working fine for me:
https://www.mediafire.com/file/2wr29jjboqpqjhq/MusicBee_Wifi_Sync_Android_13.apk/file
 sorry, i don't remember which form member has prepared this version and where i have downloaded it from.
Dzib
Hi there!
I am getting an error while trying to sync my PC with Xiaomi 12 Pro. There is message "MusicBee can't match the device name to an existing configuration. Enter the device name that is displayed in MusicBee:". I think that the problem is in technical naming of my device. While MusicBee on my PC identify it as "Xiaomi 12 Pro", MusicBee Wifi Sync says that its name is "2201122G". I tried to enter "Xiaomi 12 Pro" into the input field, but it doesn't work for me. Also I already tried to reinstall both apps on PC and android device, delete device on PC and do a wire-sync again, so I have no idea what should I do next
I have the exact same error with Xiaomi Redmi Note 12S, but it was working fine with my Redmi Note 8 Pro
Edit 1: Looks like that on some phone models, the device model is used instead of the device name, so Musicbee is creating a device "profile" based on the device name while the wifi app is using the device model, so it can't work. A solution would be to be able to change de device name in Musicbee to match the one in the app, is it possible ?
Edit 2: It's working !!!! Juste changed the name of the device in MusicBee3Settings.ini (under Device - DeviceSettings) to match the model of the phone.
Last Edit: September 21, 2023, 02:09:06 PM by Dzib
