Author Topic: Wifi android device synching  (Read 434303 times)
can you do a simple test of playing a track, doing a sync preview and then checking in MB if the play count has incremented by 1
chrisdivine
Hi! Maybe this information helps someone:
I had problems, that were caused by the different wifi bands of my router. It sends with the same ssid in the 2,4- und 5-GHz bands. If android phone and my notebook are in different bands (but the same network), I get an connection error trying to sync.
chrisdivine
christmw2503
All play counts are synced successfully. It's only tracks I played before that aren't synced.
if you are referring to the tracks played on the device, the reverse sync is incremental.
So on the very first reverse sync, the full play count should have been sync'ed back to your musicbee library. And afterwards, only the change in play count.
If you want, you could delete the sync state file from the device by clearing the storage used by the app. However it would mean you also lose the settings
vpsaxman
I'm experiencing the same issue. If my phone and PC are on different bands, the sync notification appears and hangs forever. The app's activity doesn't update and nothing gets synced.
I can also confirm that using the same band on both devices fixes the issue.
This does NOT happen for Playlist Sync by the way, just regular ("Full"?) sync.
Joker73R
What does the MusicBee app "files as configured in MusicBee" option stand for?
chrisdivine
I want to report an other issue. Sync with mp3-files works quite well, but not reliable, when I sync flac files converting to mp3.
I have a lot of flacs and use the option to convert it on the fly to mp3. In the playlists are 30 - 600 files. The short ones are transferred, but syncing hangs with the longer.
It means that the parameters for the sync are those as specified for the device under Preferences > Devices
Joker73R
Thanks for the clarification. One thing that I don't understand: All my mp3 files have their album covers embedded, but if I don't check to embed them during the transfer to the device the songs don't have their covers even though those covers are embedded on the file apart from MusicBee.
Why would you tell it not to embed them on the device if you want them embedded on the device?
Joker73R
Because those files already have the covers embedded before being added to the MusicBee library.
What I'm getting at is that you're telling it to erase that embedded art on transfer by doing that.
Joker73R
Ah, understood. Thanks for the clarification. I also have lyrics embedded in the mp3 files and even though I don't select the option to embed them during the transfer to my device they still keep inside the mp3 file. I thought album covers would have the same behaviour. Apart from that misunderstanding, syncing works great. I've two suggestions:
- Add a shortcut to launch the syncing without opening the app via Tasker, for example.
- After syncing is finished, we should return to the main window by pressing "back" button on the phone instead of the "sync more" button.
- If I stop the syncing, the persistent notification gets stuck and I can only get rid of it when forcing its close.
- I love that the MusicBee computer program shows you the syncing percentage but, could you add the estimated remaining time? Or the songs that are being copied to the device.
- Touching the syncing notification should open the app.
Last Edit: May 25, 2019, 08:41:00 AM by Joker73R
