Author Topic: Wifi android device synching  (Read 446042 times)
i can see i need to make one more change on the android side, so will do that
edit:
v0.5.8
https://play.google.com/apps/internaltest/4700978781087552506
the device name override prompt should now appear after "Locate" fails for the first time.
Last Edit: April 18, 2019, 06:23:02 PM by Steven
Babydoll32
edit:
v0.5.8
Thanks Steven!
Seems to work fine now! Also playcount sync with GMP.
I have just noticed the reverse sync play count change is unnecessarily re-saving the musicbee library file ie. saving it with no changes. I will fix that for the next MusicBee patch update
edit:
Last Edit: April 19, 2019, 11:40:27 AM by Steven
Anyone who is interested to try out the GoneMad reverse sync should send me their email address they use for google play so i can add you. Also anyone interested in reverse sync of play-counts from PowerAmp should do the same
The android app is available at:
You also need the latest patch version of MusicBee v3.3.7049 +
SkyZippr
I can't get Wifi reverse sync to work. After I press 'Preview', I get 'File not matched in MusicBee' error and 'WARNING: 964 files will not sync'.
Error log is too long to post, but it seems to be simply a list of 'File not matched in MusicBee' for every single song in my GMMP library.
I don't know if it matters, but I have way more than 964 songs in my library.
I've done a wired sync, and then a Wifi sync, both of which was done without any error.
My wifi app version is 0.5.8, and my MusicBee version on my PC is 3.3.7050.
can you post a screenshot of the device settings in MusicBee, especially the naming templates (Preferences/ Devices/ and open the device in question)
and then could you provide the full path as seen on the device for one of your music files
SkyZippr
Screenshot:
Would this suffice? The device name would be MHA-L29, which is a Huawei Mate 9.
The path for SD card means 'Samsung's memory card', as my phone is Japanese localized.
I know it should have some internal name like /storage/sdcard, but my phone doesn't show it.
The stock file manager shows full path as, for example: メモリーカード/Music/2Pac/All Eyez On Me/1-03 Skandalouz.m4a, with 'メモリーカード' being 'memory card'.
The SD card is shown as simply 'memory card' on the phone, but when it's connected to my PC it's 'Samsung's memory card'.
I guess it has something to do with the error?
could you run this debug version of MB - unzip and replace musicbee.exe
https://www.mediafire.com/file/k8pkr4y8a9d9g7v/MusicBeeDebugSync.zip/file
It will log some info at the end of the error log (help/ support/ view error log) starting with the text:
mtp root=
MCDoubleDefDP
mtp root=
He appears to be having the same issue I am where reverse sync cannot locate files if I use the "preserve folders and filenames" option. If he resyncs his music using the "use naming template" option, it will work.
SkyZippr
mtp root=
This is strange. With this version, I seem to be having difficulty with WIRED syncing.
During copying playlists, a red message appears at the bottom: 'Synchronization has temporarily stalled for 2-5 minutes while the device processes current file operations. For the next sync, moving playlists folders to Music\Playlists in the settings tab will help.'
I've already moved my playlists to that folder earlier.
Wired syncing now takes 10+ minutes just to transfer 5 playlist files.
I'll give it a try. But since I live in Japan (GMT+8:00), I might to slow to respond.
i just need you to run a reverse sync and send me the info in the musicbee error log
edit:
nevermind - i can reproduce this issue myself
Last Edit: April 22, 2019, 09:22:24 AM by Steven
SkyZippr
This should fix the issue:
Thanks Steven!
Just confirmed that reverse sync now works perfectly for updating both play count and rating.
Reverse Sync of playcounts and ratings is now available for PowerAmp. You will need to send me your email address for google play so i can add you.
Of course GoneMad is already available on the alpha channel. I am not planning on adding support for any more players for now.
You also need the latest patch version of MusicBee v3.3.7051 +
Last Edit: April 22, 2019, 04:59:29 PM by Steven
christmw2503
Any rating done in Poweramp will sync to a half star in Musicbee. Gonemad ratings do match. Do I have to join a log?
