Author Topic: Wifi android device synching  (Read 442058 times)
Using MB v3.5.8659 P
I've been using Steven's WiFi Sync app ever since it was introduced. A while ago my Galaxy  S22 updated to Android OS 13 and the WiFi sync app continued to work flawlessly.
This past weekend the phone died and I was sent I replacement. Everything is the same (including the model number (SM-S901U)) but the sync app now does not work. I get the dreaded "Can't use this folder" error. I downloaded and installed the "new" complied apk and started a sync which resulted in a lot of these in the sync error log.
java.net.SocketException:java.net.SocketTimeoutException:Read timed out
In the MB error log each file that was attempted to transfer threw a "I/O error occurred. What was even weirder was the MB's status bar showed that the sync had completed successfully. Even though nothing was transferred.
Needless to say (but I'm going to say it anyway)  I'd really like to get this working and ideally using the S22's root folder.
Any ideas?
Last Edit: September 21, 2023, 09:30:42 PM by phred
Dzib
How did you fix the "can't use this folder" error ?
If I recall, using the new, compiled apk took care of that.
For the record I'm on the third day of (almost) non-stop configuring the replacement phone. With this particular issue I tried a lot of things so I may be getting mixed up in the sequence and/or results.
Dzib
The apk on the last page? That's the one I used but without success unfortunately
Guapdad
The My Files app on android won't allow me to do a two way wifi sync. Saying I need to select the SD card root folder and not one of it's sub folders. From what I've read here in the forum this doesn't look like it will be fixed anytime soon. At least until google decides to let us have write permission on our own devices.
Wondering if we could get around this by using as an alternate file management app. The wifi sync app defaults to using the android file management. Any chance we could add an option to select the file management app we want to use for wifi sync?
sibilla6
Seconding what Guapdad said. I have a new Samsung phone and I tried the apk from this thread and when I try to preview it asks for me to choose the root folder through the default file manager, which blocks it by saying "to protect your privacy, choose another folder". I don't want to have to root my phone for this and create all sorts of trouble, please let us use another folder or another file manager.
ry49
Same here on my Pixel 8 Android 14 :'(
sageleader
Confirming as well that the Wifi Sync app isn't working on Pixel 8 Pro (Android 14). I tried the stock app as well as the APK someone modified here. Even with the All Files Access setting enabled I still am unable to select the root folder. Yes I have restarted.
Squabsy
No that doesn't work on Android 14 ... was working fine with a version I built re the previous instructions but now I've upgraded to 14 I'm getting the SDcard error on all builds I've tried (knew I shouldn't have updated) I'm on a pixel 4a 5g if thats relevant
bigdenver
Just FYI - my LG V60 is running Android 13 and the new APK does not work.  Same SD file access error.
Xeknos
Hello,
Echoing this. With the recent Samsung Galaxy S23+ update to Android 14, the current APK no longer works. Possible to update so its compatible with 14? Are there other workarounds?
Last Edit: November 22, 2023, 09:01:18 PM by Xeknos
MrVain712
Hello,
I have the same problem :( :(
MrVain712
Hey @all,
this Video helps me with Android 14: Youtube
This is important:
Fix If you don't see it the miexplorer stuff when the menu opens
go to settings ->components ->scroll down ->Turn document provider on, all done.
