Author Topic: can not add tracts to playlist  (Read 719 times)
movebetter
MusicBee 3.2.6902
windows 10
setting up Musicbee on new computer. old version on old computer i could drag and drop tracts from explorer into playlist but it wont work in this case? any suggestions? thank you...
Windows Store version? Or installer? Or portable?
If either of the first two, the issue may be related to the fact that the install is in a Windows protected directory. Or uninstall and reinstall the portable version in a directory that isn't protected by Windows - ideally on another partition.
If not the Windows Store version, try patching to 3.3. See my sig.
Also make sure your security software isn't blocking things. Especially Avast. Whitelisting the entire MB directory in your security software might help.
movebetter
hi, thanks for your reply. i am not sure what you are saying. I am not that great with computer stuff, i downloaded from the MB website and chose the
Start enjoying your music experience with MusicBee!
MusicBee 3.2.6902
Released on November 26, 2018
For Win7/ Win8/ Win10
Release Notes
Installer Edition
This edition will install MusicBee on your Windows system drive
 GET MUSICBEE INSTALLER
i uninstalled and reinstalled a few times.
when i try to drag the file into the new playlist a small circle appers with an x in it. i can drag files into wavepad.
does any of this help?
thanks again
movebetter
You don't need to uninstall your security software. Simply whitelist the entire MB folder in Norton.
