Author Topic: Artwork Properties  (Read 6075 times)
Munga
When looking at embedded artwork there is no way to tell size of existing file.  For instance 600 X 600 150k would be very imformative to me as i like my art to be a certain size.
Munga
Maybe somethimg like hover over with mouse could give us properties or just right clicking properties tab.   Just a thought
VX
Munga
Maleko12
+1
I would find this extremely helpful
this is done for the artwork showing in the now playing panel and tag editor panel
Munga
But there is nothing that tells you the actual size until you hit search internet and that is for a new picture not the embedded one.  Seems like once the picture has been embedded there is no way to tell what size picture i have embedded.
i meant its done for the next update which is now posted on the weekly updates topic
carloscs
Thanks, working nice.
Could you please add it to the Navigator Panel Playing/Selected Tracks too? It would be a little more complete.
Tx again.
Tx again.
it should already be done and works for me - you are refering to when the now playing panel is docked in the left navigator bar?
carloscs
Nope I mean the the Navigator Panel Playing/Selected Tracks. But as you say it works for you I looked again, and there are some strange situations.
Tests done with playing album = selected album for simplicity:
a) In Navigator Panel toggle Playing Tracks/Selected Tracks -> dimension appears in both pictures. BUT:
Playing Track shows 298x230 (correct) and Selected Tracks Show 174x174 (incorrect). When doing Track Editor->Search Internet the 174x174 is the size of the only available picture on for this album .
b) Now, with Selected Tracks chosen, in Main Panel click on the album -> the image takes a little while to change, the "new" image is noticeable different and is shown without the dimensions -> First image is the net one and second is from the album?
Edit: Now Playing->Playing/Selected Tracks has the same behaviour.
i see if you have the artwork displayed as a separate tab in the now playing panel its not behaving correctly for the selected track (its fine for when artwork is displayed in the same tab as the track details).
Its fixed for the next update
