I just installed version 3.2.6902. In my data files, I have more than one folder - each with a library of tunes either for iTunes or Musicbee. I believe one folder for each player has a version which has playlists on it that I would recognize. In order to choose the correct folder to use as a library, I would first have to see the metadata which has the playlists. First question is how do I do that? Once I find that folder, I want to use it to create a library in Musicbee (with all the playlists that were created in iTunes). Since I haven't used iTunes in several years (where the library and playlists originally came from), and I hate iTunes, I want to set myself up with Musicbee. I am trying to avoid setting up all my playlists from scratch (I have over 6,000 tunes in my library). Need a lot of expert help here. Thank you in advance.
