Released January 16, 2019. Changelog since 2.4.13.8:
2.4.14 - 16/1/2019
* Support for playback on the "No sound" device
BASS_Init
BASS_StreamCreateFile/User/URL
BASS_SampleLoad/Create
BASS_ChannelPlay
* Improved sample rate conversion quality, including 64 point option
BASS_ATTRIB_SRC (BASS_ChannelSetAttribute option)
BASS_CONFIG_SRC/_SAMPLE (BASS_SetConfig options)
* Loopback (output device) recording on Windows Vista and above
BASS_RecordInit
BASS_RecordGetDeviceInfo
BASS_DEVICE_LOOPBACK (BASS_DEVICEINFO flag)
DEVLIST and RECTEST examples updated
* Native format recording option
BASS_RecordStart
* Access to the 3D output mix for applying DSP/FX
STREAMPROC_DEVICE_3D (BASS_StreamCreate option)
* Retrieval of a device's started/stopped status
BASS_IsStarted
* Sync for when a device stops unexpectedly
BASS_SYNC_DEV_FAIL (BASS_ChannelSetSync type)
* New channel playback state for a paused device
BASS_ACTIVE_PAUSED_DEVICE (BASS_ChannelIsActive)
* Sync for when a device's sample format changes
BASS_SYNC_DEV_FORMAT (BASS_ChannelSetSync type)
* Adjustable output device update period
BASS_CONFIG_DEV_PERIOD (BASS_SetConfig option)
* Nyquist FFT option
BASS_DATA_FFT_NYQUIST (BASS_ChannelGetData flag)
* Plugin-specific flags are ignored in standard stream creation functions
* Pre-buffering during stream creation is now disabled by default
BASS_CONFIG_NET_PREBUF_WAIT (BASS_SetConfig option)
BASS_StreamCreateURL/FileUser
* Existing internet streams are unaffected by read timeout config changes
BASS_CONFIG_NET_READTIMEOUT (BASS_SetConfig option)
* Retrieval of the number of existing handles
BASS_CONFIG_HANDLES (BASS_GetConfig option)
* Windows mixer settings are retained by default and optionally not
BASS_CONFIG_WASAPI_PERSIST (BASS_SetConfig option)
* Configurable OpenSSL library filename on Linux/Android
BASS_CONFIG_LIBSSL (BASS_SetConfigPtr option)
* Fix for bug in playback buffering disabling option
BASS_ATTRIB_NOBUFFER (BASS_ChannelSetAttribute option)
* Fix to support long logarithmic curves in volume effects
BASS_FX_VOLUME (BASS_ChannelSetFX type)
Windows version downloadable at:
http://www.un4seen.com/download.php?bass24 .
