Author Topic: IMPORTING PLAYLIST FOLDERS FROM ITUNES  (Read 4721 times)
aaeiouy
I make use of extensive playlist folders and subfolders in my iTunes. Is there a way to import these into MusicBee while maintaining the folder hierarchy and playlist order? I have only been able to manually import individual playlists (that I exported from iTunes).
Thanks for your help.
aaeiouy
 A workaround...
...\MusicBee\Playlists will have all the iTunes playlists in one folder.  OUTSIDE of Musicbee, i.e. in windows explorer, duplicate by hand all folders and hierarchies. Still in Explorer, but looking in iTunes, move each playlist to the appropriate folder in Explorer. This is tedious, but I did about 400 playlists in about 2 hours. Kudos to musicbee for simply reading the folder hierarchy that it finds, when it starts.
  Maybe you all knew the above, but iTunes sticks all of this in its xml file, which is hard to edit.
petesrdic
Hey there, I'm faced with the same issue.
Not quite clear on your solution though. Could you perhaps detail further and then what file format to import in to MB.
Could really do with a working solution here. Many thanks!
