Author Topic: Sound is distorted  (Read 4959 times)
Jorus_E
This time direct after the first song. I hear song 2 and 3. Indicator jump from 1 to 3.
Stop playback and start a song is enough. Quit MB is not necessary.
Start 3. Then next 4 and 5.
Playback with the latest 3.3.6935
Yesterday, with 3.3.6932, it was not direct after the 1st.
Sorry, i must figure out where to park the settings file.
_|°~
Jorus_E
With a autoplaylist with short songs (< 1:00) its only happened as de songs are in track order. Direct after each other in a album.
Settingsfile: https://drive.google.com/file/d/1WvKDyeidCnDViHVHRMhLktVRWRY34JuV/view?usp=sharing
Last Edit: December 28, 2018, 02:32:33 PM by Jorus_E
_|°~
You both have "load entire file into memory" and cross-fading enabled. Ater long usage with stardepp's settings i could not reproduce any issues.
However I have made a change, so see if this works:
stardepp
Good, I have deactivated the transition and installed the update. Thank yours for your help.
I will tell you how MusicBee 3.3 continues to behave.
Last Edit: December 28, 2018, 03:35:37 PM by stardepp
Jorus_E
Thank you Steven.
But, with the new download 3.3.6936
Full in mem ON - Crossfade ON = Double play
Full in mem OF - Crossfade ON = Double play
Full in mem OF - Crossfade OF = Single play
Full in mem ON - Crossfade OF = Single play
I like the Crossfade. Can you restore it?
_|°~
I cant reproduce this using your settings, however try unticking "remove starting and ending silence" in the player preferences to see if it helps.
And when you say "double play" can you be more precise what you mean by that. eg. does it play two instances of the same song but with some gap and if so, what is the gap (the crossfade period?)
still try the test i requested but i suspect it happens when the next track is from the same album and you have "do not crossfade tracks from the same album enabled"
edit:
I am pretty sure this is the reason and will make a new version available after some more testing
Last Edit: December 29, 2018, 10:43:52 AM by Steven
Jorus_E
With the latest 3.3.6937 it seems oke.
File in mem is enabled
Crossfade is enabled
Not crossfade album is enabled
Skip silence is enabled
I mean with double play, playback 2 different songs in the same time. Next plus the next+1. That is over now. Tested with the same library and songs.
Thank you Steven
_|°~
