Author Topic: Editing a Skin  (Read 3520 times)
eddi
  • Writer / Music Blog / MusicBee Power User
Hi there
first of all - i´m not very familiar with skinning or editing codes!
I like the multi color skins (e.g. Sample Skin; mellon remix; scamleon etc.) - especially the fact that columns and bars have differents colors which makes every area of the main panel look neatly arranged
So is there a 'SIMPLE' possibility for me to edit these columns and bars ?
thx Eddi
You should start off by looking at the three-part skinning guide in the forum under Support > Developers' Area > Skins.
Also look at the Wiki skinning section, which may duplicate some of what is in the forum. https://musicbee.fandom.com/wiki/Skinning_Guide.
Questions relating to your skinning attempts should be posted in the Developer's Area > Skins section.
eddi
thx for the answer. So I´ll check that out to see if it is easy to handle.
