Author Topic: single full screen wide progress bar / wavebar  (Read 2151 times)
tmprojection
Hey, under my player controls elements i have a wave bar, i want to use this rather than the player controls progress bar as it is full screen wide, however this creates two progress bars as you can see here:
is there anyway to disable the other progress bar?
i can select the wave bar in player controls element however  this isnt full screen wide
thanks for taking your time reading this
update to v3.3 and you can hide the progress bar in the player panel
tmprojection
awesome thanks so much mate
another question, is there a way to display statistics of the current main panel, like total tracks, total artists, total albums
i know it comes up in now playing, or column browser, but what about for the main panel?
tmprojection
just upgraded, however on the download section latest is:
MusicBee 3.2.6827
was that a type by chance? version 3.3 isnt in the download section i believe
anyway, with that versioni went into arrange panels, and unchecked player controls, but that removes all player controls, is there no way to remove just the progress bar?
The 3.3 beta download is always at this link, and is updated often;  extract the whole contents of the zip into your current MusicBee folder, letting it overwrite existing files:
tmprojection
perfect, solved, thank you :)
