Author Topic: MusicBee 3.3  (Read 266322 times)
**** see the last post for the latest update ****
The beta series for v3.3 has started and will be updated with more enhancements over the coming months. See the last post for the most recent download link.
Follow https://twitter.com/MusicBeePlayer for notifications when updates are made available
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_3_6889.zip
backup
https://www.mediafire.com/file/u3n3vpnyyt9fexl/MusicBee_Setup_3_3_6889.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_6889.exe
Podcast Enhancements
- now supports grouping subscriptions by folder
- the folders panel can be displayed by clicking the Podcast header, and tick/untick "Show Folders Panel"
- when the folders panel is displayed, you can drag/drop subscriptions to a folder to easily re-organise your subscriptions
- new % Played field displayable in the main panel thats shows for episodes that have been started, and not completed, the % of the episode played
- visual indicator that indicates podcast subscriptions that have failed to update (check the error log for details of the error)
- option to only show downloaded subscriptions (click the Podcast header, and tick "Show Downloaded Episodes Only")
- when viewing the episodes of indiviual subscriptions there is a button to toggle displaying Unplayed episodes only or all episodes
- hotkeys to speed or slow the Tempo in 10% steps, and a hotkey to reset the Tempo:
  Player: Tempo Decrease (-10%)
  Player: Tempo Increase (+10%)
  Player: Tempo Reset
- see: https://getmusicbee.com/forum/index.php?topic=26980.0
Radio Enhancements
- now supports grouping stations by folder
- you can drag/drop stations to a folder to easily re-organise your stations
- the folders panel can be hidden if you dont want to use it
- radio stations can be manually sorted (click the Radio header, and tick "Manual Station Sorting")
- see: https://getmusicbee.com/forum/index.php?topic=27012.0
Display Enhancements
- new default skin
- support for windows 10 style icons and better icons for high-dpi screens - its up to the skin authors whether they can to make use of these
- various skinning enhancements that will be used by some skins
- see: https://getmusicbee.com/forum/index.php?topic=26532.0
- and: https://getmusicbee.com/forum/index.php?topic=26914.0
Device Synchronisation
- option to replace the genre in synchronised files with the "Genre Category". Also this option ensures only one genre is present in the file
Player Enhancements
- option to display the playing track text on multiple lines. Right click on the player panel/ Panel Layout/ and tick "Show Track Details on Multiple Lines". This option is not available for all skins
- option to hide the progress bar. You might use this option when displaying a wavebar in the main panel. Right click on the player panel/ Panel Layout/ and tick "Do Not Display"
- wavebar can now be configured to show 2 wavebars - one for each channel
- hotkey for "Playback: Play Displayed Files Shuffled"
Other
- when pasting album artwork, you can now "Paste Add" to add a new picture
- when pasting artwork, you can now specify a custom location when saving the pasted picture
- sorting tracks in the main panel is now approx 50% faster, although you probably wont notice unless you have a large collection
- updated to .NET 4.6.1
- various bug fixes
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
https://getmusicbee.com/patches/new3.3.txt
edit:
links updated to fix a couple of bugs reported
Last Edit: November 25, 2018, 09:16:15 PM by Steven
https://www.dropbox.com/s/j3rh5d3fa524ag7/MusicBee_Setup_3_3_6904.zip?dl=1
backup
https://www.mediafire.com/file/87clz4k28j3x8j6/MusicBee_Setup_3_3_6904.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_6904.exe
- Highlighting rules now supports the display of up to 3 matching highlighting rules - see https://getmusicbee.com/forum/index.php?topic=27135.0
- Radio panel now supports an thumbnail layout to display the stations
- Tweaks to the default layout in the player panel
- Corrected replaygain handling for OPUS files - see https://getmusicbee.com/forum/index.php?topic=26954.0
- Fix for iTunes store API changes ("More Albums" in the Music Explorer)
- Various bug fixes
edit:
link updated to fix a bug with podcasts not remembering the last position
Last Edit: March 05, 2019, 05:49:55 PM by Steven
https://www.dropbox.com/s/s1ltdz3hwojrtw2/MusicBee_Setup_3_3_6962.zip?dl=1
backup
https://www.mediafire.com/file/f3r835ood1xinez/MusicBee_Setup_3_3_6962.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_6962.exe
- Various reliability and performance improvements for device synchronisation. See https://getmusicbee.com/forum/index.php?topic=27681.0
- Improved memory management which should address Out Of Memory exceptions some people experience
- Various bug fixes
Last Edit: March 05, 2019, 05:50:15 PM by Steven
https://www.dropbox.com/s/i879phowk7obboy/MusicBee_Setup_3_3_7016.zip?dl=1
backup:
https://www.mediafire.com/file/dnv585g61rjgdjk/MusicBee_Setup_3_3_7016.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7016.exe
- Support for one-way Wifi sync to an Android device (Lollipop 5+)
  see https://getmusicbee.com/forum/index.php?topic=28093.0
  the android app will be available for beta testing:
  https://play.google.com/apps/testing/com.getmusicbee.musicbeewifisync
- Various bug fixes
edit:
links updated to accommodate some minor changes to the wifi sync functionality
Last Edit: April 22, 2019, 08:39:38 PM by Steven
https://www.dropbox.com/s/nmv9tn9l6y8kv2a/MusicBee_Setup_3_3_7056.zip?dl=1
backup:
https://www.mediafire.com/file/000os3basgxjnlq/MusicBee_Setup_3_3_7056.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7056.exe
- Support for reverse Wifi sync from an Android device (Lollipop 5+) for GoneMad Player and PowerAmp
  - includes ratings, play counts and playlists (GoneMad only)
- speed improvement for some auto-playlist and playlist mixer settings (eg. select by Album)
- Various bug fixes
translator file - no changes
edit:
links updated to fix a bug when saving artwork in the tag editor
Last Edit: May 18, 2019, 11:22:48 AM by Steven
https://www.dropbox.com/s/rj4c35gx1m76igb/MusicBee_Setup_3_3_7085.zip?dl=1
backup:
https://www.mediafire.com/file/jk8uzdpipzbdjp3/MusicBee_Setup_3_3_7085.zip/file
this is an incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7085.exe
Unfortunately last.fm introduced some changes to the usage of their API and MusicBee is currently exceeding those restrictions. As such I have made a number of changes. The functions still implemented are:
  - scrobbling
  - playcount sync
  - track love and track love sync - however track love now updates last.fm only if the "synchronise Track Love to last.fm is enabled in the last.fm plugin preferences ie. without that being set, track love now only updates the musicbee database
  - artist biographies
  - similar artists
- as a fallback, spotify is also used for similar artists if none are found on last.fm or last.fm is failing
- as a fallback wikipedia is used if last.fm artist biography fails - however wikipedia is not ideal as its not specifically focused on music/  artists and i am expecting there will be some cases of rubbish results
- for artist thumbnails, fanart.tv is still used but as a fallback, spotify is used
- for artist pictures, fanart.tv is still used, now along with Wikipedia and Google. The results from google can be great or can be unrelated for some artist names so you can disable google in the Now Playing panel settings
- the last.fm cloud tagging is removed
- for auto-tag by album, spotify is used where last.fm was used for genres
I am told that last.fm track love and user playcount sync will be excluded from rate limiting late by the end of the week
edit:
fixed bug in spotify api
edit 2:
improvements to artist picture search
Last Edit: May 27, 2019, 09:47:42 PM by Steven
First release candidate:
incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7088.exe
https://www.dropbox.com/s/nkea9tbvuyhkwwc/MusicBee_Setup_3_3_7088.zip?dl=1
backup:
https://www.mediafire.com/file/1dvz43hmg5gej44/MusicBee_Setup_3_3_7088.zip/file
or the full download, including updates to skins and localisations
https://www.mediafire.com/file/px2jeq6q6yl4qnu/MusicBeeSetup_3_3_RC1.zip/file
portable:
https://www.mediafire.com/file/x4d19j1uz1pziby/MusicBeePortable_3_3_RC1.zip/file
edit:
links updated to fix icon display bug
Last Edit: June 04, 2019, 06:40:44 PM by Steven
Second release candidate:
incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7094.exe
https://www.dropbox.com/s/n4givtzdhlbjrj7/MusicBee_Setup_3_3_7094.zip?dl=1
backup:
https://www.mediafire.com/file/14za3yl64fx9lt6/MusicBee_Setup_3_3_7094.zip/file
https://www.mediafire.com/file/mb89lg66icc2s01/MusicBeeSetup_3_3_RC2.zip/file
portable:
https://www.mediafire.com/file/xj1a6c6z6u3cklx/MusicBeePortable_3_3_RC2.zip/file
Last Edit: June 11, 2019, 06:45:17 PM by Steven
Third and hopefully final release candidate:
incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7101.exe
https://www.dropbox.com/s/vp2xkm16pznygeu/MusicBee_Setup_3_3_7101.zip?dl=1
backup:
https://www.mediafire.com/file/sd7na722twhdebh/MusicBee_Setup_3_3_7101.zip/file
https://www.mediafire.com/file/b6fsstxwwz4nerh/MusicBeeSetup_3_3_RC3.zip/file
portable:
https://www.mediafire.com/file/5p9tcdegarg0jhd/MusicBeePortable_3_3_RC3.zip/file
Last Edit: June 18, 2019, 08:39:58 PM by Steven
There have been enough bugs fixed to justify one more release candidate.
incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7115.exe
https://www.dropbox.com/s/25thqrthq6lgy9y/MusicBee_Setup_3_3_7115.zip?dl=1
backup:
https://www.mediafire.com/file/5m19o846k407oow/MusicBee_Setup_3_3_7115.zip/file
https://www.mediafire.com/file/d5t19v98b547hkk/MusicBeeSetup_3_3.zip/file
portable:
https://www.mediafire.com/file/ncbf9q7ieo36nxc/MusicBeePortable_3_3.zip/file
edit:
links updated to fix an issue with chiptune files
Last Edit: August 03, 2019, 02:40:17 PM by Steven
Updating the official release with a number of bug fixes. I will post a link on the downloads page and update the store version over the next week.
Incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7165.exe
https://www.dropbox.com/s/iy6j5n2h0vvikzc/MusicBee_Setup_3_3_7165.zip?dl=1
backup:
https://www.mediafire.com/file/pv4t00nsjfel3mv/MusicBee_Setup_3_3_7165.zip/file
https://www.mediafire.com/file/lcsgyppojc43o0p/MusicBeeSetup_3_3_Update1.zip/file
portable:
https://www.mediafire.com/file/aclnp3sdzb9yn94/MusicBeePortable_3_3_Update1.zip/file
Last Edit: October 28, 2019, 07:30:51 PM by Steven
Incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7252.exe
https://www.dropbox.com/s/x5406hpblv5tqfr/MusicBee_Setup_3_3_7252.zip?dl=1
backup:
https://www.mediafire.com/file/bqv9ekt1kxv18f7/MusicBee_Setup_3_3_7252.zip/file
https://www.mediafire.com/file/pb7da8uerxbtyjy/MusicBeeSetup_3_3_Update2.zip/file
portable:
https://www.mediafire.com/file/opw9nixkxy4f88f/MusicBeePortable_3_3_Update2.zip/file
edit:
links updated with a couple more fixes and fix for DSD DOP handling
Last Edit: November 16, 2019, 10:24:16 AM by Steven
Due to a significant issue with CD handling I am going to do another release. I will post a link on the downloads page and update the store version over the next week.
Incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7261.exe
https://www.dropbox.com/s/wdefop9jv8idfnq/MusicBee_Setup_3_3_7261.zip?dl=1
backup:
https://www.mediafire.com/file/cgd57ra74zvrves/MusicBee_Setup_3_3_7261.zip/file
https://www.mediafire.com/file/n5r06cvoc03y25g/MusicBeeSetup_3_3_Update3.zip/file
portable:
https://www.mediafire.com/file/cdodp6mbgnhqhgu/MusicBeePortable_3_3_Update3.zip/file
Last Edit: January 06, 2020, 06:06:46 PM by Steven
Fixes a number of bugs found. I will post a link on the downloads page and update the store version over the next week.
Incremental update and includes all changes since version 3.2 - unzip and then run MusicBee_Setup_3_3_7310.exe
https://www.dropbox.com/s/e1pcln6312gjgao/MusicBee_Setup_3_3_7310.zip?dl=1
backup:
https://www.mediafire.com/file/c6hqrs7vu5ybx5b/MusicBee_Setup_3_3_7310.zip/file
https://www.mediafire.com/file/eo3212yr7370idt/MusicBeeSetup_3_3_Update4.zip/file
portable:
https://www.mediafire.com/file/ocl0n2qujig7tui/MusicBeePortable_3_3_Update4.zip/file
Last Edit: March 05, 2020, 08:11:01 AM by Steven
