Author Topic: Static Playlist  (Read 867 times)
Johan
Can I lock some tracks in the playlist and then shuffle the rest?
ma_t14
When you select the tracks and open the tag editor, in the settings tab there's a "keep tracks in sequence when shuffling" option. Is this what you are looking for? Or do you want the numbering position of specified tracks in a specific playlist to remain constant?
Johan
Thanks, yes the latter. I have some medleys which consist of a few tracks that needs to stay intact.
ma_t14
If it's just a case of always keeping a sequence of tracks together then the option I mentioned above will do the trick otherwise if you want to give tracks a fixed number position in the playlist while the rest can change through shuffling then this is not possible as far as I know.
Johan
Thanks for your answers. One option that might work is to just drag those tracks in sequence and leave the others shuffled.
ma_t14
Could you describe your usecase a bit more in depth? Someone might be able to offer a solution.
