Author Topic: Play music through DLNA device - Arcam Solo Music  (Read 1038 times)
Truman beric
Hi
I'm a total Newbie with MusicBee, just downloaded it.
I would like to play music through DLNA device, the Arcam Solo Music.
I previously used Foobar 2000 and I just had to select it in Preferences>Output>Arcam Solo... I don't have this choice in Music Bee so I wandered it it was even possible to play my music with the Arcam after all
Anyone has ever had that kind of question ?
Thank you
Edit: Before you ask, I've had installed the UPnP pluggin and check the "enable MusicBee to play to a UPnP device"  but it still won't detect the Arcam Solo Music ;..
Last Edit: November 01, 2018, 04:50:00 PM by Truman beric
First, the DLNA plugin is no longer supported.
Second, you might be better off posting your question in the plugin's thread as someone who is familiar with its workings might be able to help.
I removed your duplicate post - phred meant that you post it on the DLNA topic, not create a new topic.
To answer the question you asked, you best stick with foobar if playing through DLNA to your device is important to you and its not working with the MB plugin
