Image:
http://slein13.homedns.org/Junk/MB_Album_setup.jpgNow playing list is now at the bottom. As you can see there is empty space at the left side of MB I would like to put the now playing list there (under Library and playlist links I don't really use) and above the album art and track specific information at the lower left corner. I know I can't place all information then in the now playing list but I really only want to see track nr, title and duration.
As you can also see in the now playing list it shows track nr 4000+ while it only plays the current album and then (jumps) selects a new one to play because of the shuffle. So technically it is showing correctly because it will play all the albums if given the 13 days to play but I would rather only see the currect tracks of the current album playing.
That raises a question is shuffle a repeating cycle of all albums or just random jumps to albums with no history?
example: albums: 1, 2, 3, 4
shuffle: 2, 4, 3, 1, | 4, 3, 1, 2
random: 2, 3, 2, 4, 1, 2, 4, 3
