Author Topic: Unexpected Error Occured  (Read 977 times)
Bentley
MusicBee v3.2.6827.32939 (Win10.0), 21 Oct 2018 13:23:
   at MusicBeePlugin.BackupType.save(String fileName)
   at MusicBeePlugin.BackupIndex.saveBackup(String backupName, String statusbarText, Boolean isAutocreatedParam)
   at MusicBeePlugin.Plugin.regularAutobackup(Object state)
   at System.Threading.TimerQueueTimer.CallCallbackInContext(Object state)
   at System.Threading.TimerQueueTimer.CallCallback()
   at System.Threading.TimerQueueTimer.Fire()
   at System.Threading.TimerQueue.FireNextTimers()
   at System.Threading.TimerQueue.AppDomainTimerCallback()
This might be caused by one of your plugins. Suggested fix is to disable all of them and then add them back in one at a time until you find the culprit. And then post it on that plugin's thread so the author can address it.
Bentley
I tried placing this in the plugin forum but it does not show. I found it to be plugin 'additional tagging tools' that was causing the issue.
