Author Topic: Convert Spotify Local File Playlist to MusicBee Playlist?  (Read 2734 times)
Darkenslasher
I have quite a large collection of local files I've made a playlist of on Spotify by filtering through all the songs I disliked, however I want to convert to Musicbee. Is this possible, I have all the files on my computer, I just don't want to go through the time of individually selecting and filtering through the songs for Musicbee.
Blyssee
Yes,you can. but you need the help of 3rd party tool like Tunelf Spotify Music Converter to download and convert music from Spotify to MP3 then import to Musicbee.if you want better audio quality you can set the output format as WAV or FLAC. ;)
MusicbeeYisa
The biggest problem you have is that Spotify music files come with DRM protection and cannot listen to on other devices or media players. Even though you have a Premium account to download songs, you can only play them offline on Spotify app. To convert Spotify playlists and import to MusicBee, you have to resort to dedicated Spotify music converter, like AudBite Spotify Music Converter, or free online Spotify downloader. The playlist, track, album, podcast, and audiobook are supported. Quality can be lossless, 320kbps as original as you hear in Spotify.
JunneMendes
Hi there! 👋
Even though Spotify lets you play local files inside its app, those files can’t be easily exported or used elsewhere unless they’re converted properly. That’s where DRmare comes in handy.
If you’ve created a playlist in Spotify that includes local files, and you want to convert that into a playlist you can use in MusicBee, here’s a way to do it — using DRmare Spotify Music Converter.
