Author Topic: New default skin for v3.3 and "slim" icons  (Read 30678 times)
These are addressed for the next update. Note that metro buttons are not supported for slim icons due to their size
Repeat One button has no mouseover image.
Any skins containing Compact.Player.MetroButton element doesn't display slim player controls properly when wavebar is enabled in compact mode.
Last Edit: May 25, 2019, 09:40:02 AM by Steven
Would be great if you could support either fg2 for Panel.Body.Highlight and Panel.ChildBody.Highlight or a skin setting that forces fg to both text and icon for the two elements though I'd prefer the former.
for the next update, when highlighted, the text colour is used
Last Edit: May 25, 2019, 10:11:29 AM by Steven
For some reason, again I still can't get the updated patch from the link. I had to use a proxy to download the latest one.
Thanks! But now it keeps showing the black color when lowlighted. Can you make it use the text color when lowlighted as well?
The album icon in library explorer has the same issue.
I found out other browsers are downloading the latest version properly, and it was an issue with Chrome that cached the file.
After clearing all cache, it now downloads the updated patch.
https://superuser.com/questions/344087/does-chrome-cache-a-downloaded-file
These changes introduced a new bug. If you right-click on any library filter, all others nodes below it disappear from the left navigator.
I've PMed you all my slim version skins. Try with any of those, but for some reason this doesn't happen with the default skin.
Last Edit: May 26, 2019, 07:05:59 AM by redwing
It's IconColourOverride.Default element that causes the issue.
Last Edit: May 26, 2019, 10:51:12 AM by Steven
Then 28X15 icon support only helps users of pre-3.1 version of MB? Doesn't it matter with Windows version?
If so, I will stop supplying them as well.
I noticed this icon is still used for the close button of tag/artwork manager. As I no longer supply them for my skins, the auto-generated mouse-over color for the button with dark skins is too dark (try with Dark-Fine Tuned skins). Can you fix it?
Otherwise, I'll have to update skins with the icons included.
this should work better:
the image is entirely auto-generated and does not use any included icons
I see. It works great now. Thanks for the fix!
