Author Topic: "Windows" theme XML  (Read 3399 times)
I_Tichy
Does anyone know how to extract the XML for the basic windows theme?  I love how well it meshes with the general look of windows 10, but it's geared to windows 10 "light" theme and I'd like to rework it to better reflect window's dark theme.
There is no xml for that theme, which makes it use Windows defaults.
confirming its built into the program and there is no editable file
MB won't start with this skin:
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.#=zyzqGpOiyznOO.#=zHDSK2ho=()
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.#=zyzqGpOiyznOO.#=zXQp0hrNvhb8nAgjk_g==()
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f..ctor()
   at #=zsSqWEB_uCfYs1RIo5gmlWEiXxs7c.Main(String[] args)
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.#=zWLhvYwvTVnnM(#=zT5HoQ2qO__Vj #=zOgLdSDY=, Boolean #=zNlAJYoXAwovXqBWYkA==)
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.#=zJ5P_xuL4Rvqg()
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.#=zh18emMCwUthi(Rectangle #=zgiY3TkblnaXty2JpXvis0EQ=, Rectangle #=zr2bxp12u2cH0bRJfPIpJ9Yw=)
   at #=zQIfGmiQAWnk9IuMpzXYchWI=.OnResize(EventArgs #=zEur02jw=)
   at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds()
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=zQIfGmiQAWnk9IuMpzXYchWI=.WndProc(Message& #=zegEA_m0=)
   at #=zHUWzn2$FCa1h2fa8f$kmRbXe030f.WndProc(Message& #=zegEA_m0=)
would you mind sending me your settings file? I cant reproduce this
I_Tichy
Forgot to ever say thanks for the responses, sorry about that.
