Hello together,
I have a question about configuring the field <Playlist> in the "track information" panel.
Generally I want to display the names of all playlists a particular track is part of, which I did over a single field where I have configured the "max. row span:" with 10 and enabled the general checkbox "split multi-value tags into rows", which pretty works well as you can see on the screenshot.
But now I want to have this list of playlist names sorted.
I thought this will work over the function, which can also be found in the "Function Selector", $Sort(<Playlist>), but that doesn't work.
So am I doing something wrong, or do I need to configure it diffently, or do I need to prepare the field <Playlist> before I put it into the Sort() function, because generally the field <Playlist> is a semicolumn separated list, isn't it?
It would be really great if somebody would have a hint or solution for this sorting of the field.
Thanks a lot in advance for your help,
all the best from Austria
