I'm managing the music files manually, because multiple PC have access to them on the LAN they are read only, and currently they have a structure like this "Grouping\A\Artist" now I want to change this to something else like "A\Artist".
Just moving a directory elsewhere and doing a "Rescan All Files" did not work as expected.
Is there a way for musicbee to correctly associate the files again after I move them so they match with the internal metadata e.g. play count and rating?
My files are all in cue/image.flac format and contain musicbrainz IDs e.g. "REM MUSICBRAINZ_ALBUMID "36753db7-a19f-4477-84ae-58da939c8df5"".
I just had a look at "MusicBeeLibrary.mbl" which seems to reference the flac files but not the cue.
If there's no other way maybe I could edit this file directly, is there a format specification for this?
Also consider this a feature request so musicbee can rematch moved albums/files by musicbrainz ids.
