Author Topic: Split multiple Artists to Guest Artist  (Read 893 times)
Babydoll32
is there a way to set multiple artists fields automatically to guest artist and leave only the first on artist, without ticking every time dropdown while splitting?
Last Edit: August 25, 2018, 01:40:00 PM by Babydoll32
  • MB Version: 3.6.8878 P
You could do this with the Advanced Tagging plugin.
You would need to combine the
Remove first item from multi-item 'Artist' *
and
Remove all items from multi-item 'Artist' except first one *
and create your own custom preset to do it.
Babydoll32
Hi, Bee-liever.
Thx for your answer. Tried to find out, what you mean, but I'm too stupid create such a preset. Additional Tagging Tools are too complicated for me (except a few functions). Think I do it manually further.
Best regards
