Author Topic: Trouble with Last.fm playcount sync  (Read 1596 times)
Babydoll32
I've the problem, that MB won't sync playcounts back from Last.fm.
The stats plugin works and shows correctly, but MB won't. Not automatically, not manually.
I can also click the song in stats view and it jumps correct to song in library.
I don't know, where's the problem with playcount  :-\
The problem might be with last.fm eg. there might be a delay of some time before the data shows up in the API MB uses.
Otherwise the playcount cache can get out of synch with last.fm so try deleting:
C:\Users\<your id>\AppData\Roaming\MusicBee\LastFmPlayCountCache.dat
The first re-synch will take a long time
Babydoll32
Hi, Steven.
Thx for your fast answer. Tried Cache delete, but didn't work. Other songs get's updatet, but this one and another one I tested won't  :(
Can it be the reason, cause it's not an official release? It was a live performence within a TV show, which never official released.
But I wonder, why it's getting scrobbled and why it appear in the stats-plugin??
Babydoll32
After spending some f### hours, searching failure in tagging, MB whatever, I think I found out the problem. It's last.fm itself. In profile settings is an option for spelling correction, by default turned on.
Disabling seems to solve it.
