FIXED: 3.2.6806
Tested on Music Bee v. 3.2.6804 and 3.2.6802
Description:
When you have a custom layout in one tab which has a panel with a hidden header and another tab with a different custom layout with the same panel with the header visible, upon startup, the panel in the second tab will have its header automatically hidden.
(Example) Steps to Recreate:
1) Create two tabs.
2) In both tabs, add the 'Track Information' panel.
3) In tab one, make the header hidden, in tab two, make the header visible.
4) Save both layouts to custom layouts.
5) Restart Music Bee. Both headers will be hidden.
NOTE: If this doesn't cause the issue, try nesting the panel in tab one under another panel (checking the box under panel layout to allow switching between panels by clicking on the header).
Temporary Work-around (forcing an update):
1) Right-click on the header of the affected panel and select "hide header" (it thinks it's still being displayed).
2) Right-click on the header again and select "show header". The header will now appear correctly.
