Not sure whether to post this in Plugins/Bugs/Here. Does the lyrics search choice "LyricWiki" refer to
www.lyrics.wikia.com? Had the occasion to be playing "Struggling at the Mirror" by "Tystnaden" on MusicBee web radio, and lyrics could not be found despite most provider choices being checked in Tags(2), including
"LyricWiki." I am running frankz's mb_LyricsReloaded plugin, but according to its search log (which I checked) this plugin does
not query LyricWiki, so I'm assuming that choice in Tags(2) is part of the built-in original sources his plugin is only designed to complement.
Note that the station involved correctly sends artist and title metadata and MusicBee DOES find lyrics for many songs from this station:
The point of this question is that when switching to Foobar while the same song was playing, it's lyrics plugin was able to find and display the lyrics from
www.lyrics.wikia.com, as shown below:
Therefore, IF "LyricWiki" is indeed the same as
www.lyrics.wikia.com, something is failing in the search algorithm being used for that database by MusicBee--can that be fixed, or if not, frankz can you add it to your own plugin?
Moderators please move post to the appropriate forum if I picked the wrong one.
