(MusicBee 3.2.6795) Current behavior in the Now Playing panel when the "Large Album" view is selected is that the album cover appears in correct aspect ratio, sized to fit the size of the view window. The entire image always appears if the artwork is of square dimension, but if it is for example taller than it is wide, the height of the image ends up getting cropped at the top and bottom to fit a square display, like this:
Is it possible to add a "Fit to Panel" option in this case so that the entire image always appears, in correct aspect ratio and resized "in toto" to match the display window size? This option already exists. and works perfectly, in the Track Information panel when "Show artwork above fields--fit to panel" is selected in its settings, when choosing to display that panel in other layout scenarios:
A similar "Fit to Panel" option in the Now Playing header option menu next to "Large Album" would be great! Thanks for your consideration.
